The below is a write I just made to document some of the design considerations I used when I put together the control and logic boards for my GP38-2 loco.
Design Concepts for the USA Trains GP38-2 using LocoFi
It was desired to use a LocoFi module to control the power applied to the two motors in a USA Trains model GP38-2 locomotive. In addition control of the lights used in this locomotive was also desired. With regard to the lights, the LocoFi module only provides for two light control outputs. The GP38-2 locomotive has front, rear and cab lighting. A method would have to be determined to control more than two lighting features.
From some initial measurements of the motor characteristics in the GP38-2, it was determined that the LocoFi module by itself could not support long term operation of the motors. The GP38-2 has two can type motors installed in the front and rear truck/bogie assemblies. DC measurement of the resistance of each motor indicated about 2 ohms resistance. With instrumentation applied to measure voltage and current applied to the motors, it was determined that approximately 2 to 3 volts DC would be required to just get the motors operating at stall speed. In other words just to get the locomotive moving when on a powered track section. If the voltage was 2 volts then based on Ohms law
E = I x R, the stall current would be 2 amps. The actual voltage required to get the locomotive moving could be higher, as it appears from inspection of the motors, they are at least a four pole or six pole type DC motor. So depending on the position of the rotor inside the motor with respect to the stator assembly, which is a permanent magnet type, it could take upwards of 2 amps of current. Possibly even 4 or 5 amps depending on the motor mechanical load to start it moving. Actual DC current measurements confirmed these assumptions. So the design goal for any motor driver circuit should be able to handle at least 2 amps of starting current, and actually more up to at least 5 amps for safety margins. This assumption would be based upon reliability of the motor driver circuit, as well as thermal management of the devices and physical layout of the electronic components used in the motor driver.
Some comments about motor drivers, and more specifically H-bridge type drivers are needed here. Since we don’t need to “Instantaneously” need to change motor direction, a real H-bridge is not needed here. Research about available off the shelf motor driver devices has produced the existence of a couple of candidates. These devices are not real H-bridge type devices in that they cannot instantaneously switch directions. They are acceptable for use in the proposed application because LocoFi requires the throttle to be returned to zero before allowing direction change. However, these type of devices are limited to about 5 amps of continuous motor drive current. Even with a heat sink applied.
Experimentation would be required to determine if these type of devices would be suitable for use with G Scale motors. Especially in locomotives with more than one motor in the unit.
Two custom designs were developed for this experimentation. One with a motor driver, the other with a real H-bridge type design. The motor driver is limited to 5 amps peak current, while the H-bridge could handle in excess of 10 amps peak current. Both would require heat sinks. More about part numbers later.
The lighting features used in the GP38-2 required a bit of out of the box thinking. Since I wanted control of the cab lighting independently from the front and rear light control of the LocoFi module I had to add a bit of logic to the LocoFi light outputs. The measured current of the lights used in the GP38-2 when using 24 volts DC to power them was about 200 milliamps. Too much for direct transistor control without heat sinks on the transistors. Relays were decided upon for control of the lights, being driven by CMOS logic from the LocoFi light outputs. Since LocoFi has two light outputs, we could define four logic states. OFF, FRONT, REAR, CAB Some surgery on the GP38-2 light wiring had to be accomplished to separate the cab lighting circuit from the rest of the lights. Diode steering is used depending on track power polarity to select the Front or Rear lighting condition in the factory stock GP38-2. At this point I decided that I also wanted to retain the ability to return the modified GP38-2 to factory wiring by using the four bottom mounted slide switches. This was accomplished very easily by the logic added to the new board design for lighting and motor control.
There are three separate circuit boards, plus the LocoFi Module involved in the G Scale
System.
1 – Main base board
2 – Motor driver or H-bridge
3 – Relay/Lighting board
The Motor driver can be replaced with a real H-bridge board capable of up to 10 amps
of drive current. The Motor driver will handle about 4.5 amps. It is an either/or selection not both at the same time. The motor driver board shown is one with the finned heat sink in the middle.
The Main board supports a platform for the two auxiliary boards. It also provides the mount surface for the four control switches to return the wiring circuits to factory stock.
Since the design goal was to support at least 5 to 10 amps of motor current, it was felt that the original stock slide switches would not suffice for reliable performance. This information was taken from the data sheet of the switch manufacturer. Why USA trains decided to use these switches in the first place is beyond me. However, running current for the two motors together is only about 500 milliamps, and in that scenario the switch
Current rating would be fine. It only the prolonged starting current that would potentially cause a problem with reliability. For this reason it was decided to use a high current power relay to route motor voltage from the pickups to the motor driver and ultimately the motors. The Main board also provides connectors for the wiring harness in the GP38-2 which includes the lighting and smoke generator connections.
The Motor Driver board shown in the above picture uses a device made by ONSEMI. Their part number STK681-360. It is not a real H-bridge, although the internal architecture looks a lot like an H-bridge. You cannot instantaneously change motor polarity with this device. And it even states this on the part data sheet. This board can be replaced with a second board design which is a real H-bridge rated for higher current. The pin out of the interface connector allows this interchange.
The Relay/Lighting board contains the CMOS logic for controlling four states from the two lighting outputs from the LocoFi board. It also contains the relays necessary and associated with providing power polarity switching for the Front and Rear lighting boards in the factory stock GP38-2.
The Main base board was designed to fit inside the shell of the GP-38-2, along with the two auxiliary boards.
I took a look at the DULLHB module reference and it does appear that the so called modified DULLHB uses both the direction signals and the PWM signal to drive the Cytron module. The module I used (XY-15AS) has a mode that requires only the two motor outputs from the LocoFi module buffered by a NPN transistor on each output. This is because the logic signals to control the XY-15AS are the exact inverse of what the LocoFi module outputs. The transistors also provide a bit of signal drive capability for the XY-15AS module, not that it needs it. I also made a comment to John in a private email about only having the ability to control one locomotive via the direct connect method from the phone to the LocoFi module. The LocoFi module uses an ESP8266 and it comes up in Access Point mode before being connected to any network. Since it is in Access Point mode any phone or other WiFi device can connect directly to it to establish a small two node network. I've never experimented trying to have one phone connected to two LocoFi modules operating each in AP mode. This could cause
problems with connectivity. I'm probably treading on trade secrets here revealing this information, but I have successfully reverse engineered the LocoFi WiFi protocol.
I think I communicated this to the LocoFi team some time ago. Since that communication I have not been involved in doing any further testing or debugging or reverse engineering with any LocoFi product. I will not disclose the protocol without prior permission from LocoFi.
Karin
John, Please note that Karin isn't using a "modified LocoFi™" system. In fact, she designed her own. In any case, the same principles apply. In either case, the modified system does not affect the WiFi connectivity.
Karin, Please see the "modified LocoFi™" being offered for reference here: https://www.wifimodelrailroad.com/forum/main/comment/84c29a1d-98aa-3edf-8f98-8170cf2748c0?postId=61c221880073320016ed9ef9
Hi John:
I appreciate your comments. Funny, coincidence, I graduated from Lehigh U.
So long ago I can't remember. I used to live in East Allen Township, worked for
Push, Pull, and Lift. PP&L to outsiders.
Anyway I will give a try and list my email here.
Karinann at tampabay dot rr dot com
I think you get the idea of what to replace in the address.
I will have to go back and review my notes about the operation of my units.
I think I have one standalone LocoFi module that I can connect to a power supply to test the connectivity. As far as I can recall I no problem doing a direct connect without
using a network connection. That worked OK. In fact if I remember correctly, after the debacle with Android version 7 sometimes that was only way I could connect.
Let's get connected directly with email, and establish some base line of how your
system is built to see if I can help further.
Cheers for now,
Karin
Passing along your direct email would not work via this forum. LocoFi does have my direct email and phone number. Maybe they would pass it along to you. Live in Lehigh U vacinity. Have both Locofi systems, DULLHA and DULLHB, that LocoFi modified for use with Cytron MD13S H-bridge. Using BLU STUDIO X8 HD with 8.1 system cellphone and a Samsung tablet.
Systems operate perfectly when phone or tablet are connected via wifi network. Using Verizon Jetpack wireless for wifi network. When jetpack is turned off Locofi system will not communicate with locomotive. Searches for loco and that is as far as it gets.
Wanted to know if you actually did a conversion using modified LocoFi systeman with an H- bridge, with and without wifi network connection. Only conslusion so far is that the modification LocoFi only works when a wifi network is available. This defeats the ability to control a locomotive without wifi network being available at club in Bethlehem.
It has been some time since I have used the system for trials. Since then I have essentially "mothballed" the GP38, and presently am not trying any experiments with LocoFi. The GP38 and all accessories are stored away in a closet. So let me see if I can be of some assistance. My original concept drawing was based upon some very custom hardware that I designed. I never actually finished building the custom H Bridge portion of the hardware design. Instead I used an H bridge I found on the web. It is labeled "XY-15AS". I had to add a couple of interface transistors drive the H bridge with the correct polarity signals. But it does work. There is a video floating around this site somewhere showing the working GP38 with LocoFi. I think it is also on YouTube somewhere too. With regard to the network connections. I don't know which version of LocoFi you are using. I used the very first version hardware board, I don't remember the version number, but probably v1.0 or 1.1. I do remember that there were some issues with early versions of the software being compatible with earlier versions of Android. I seem to remember that version 6 of Android was fairly bullet proof with the LocoFi app. At some point in time my Android phone did an automatic upgrade to version 7 and that seemed to break the functionality of the app. It had difficulty assigning and finding locomotives on the network. That was the last version I tested with. I think , but am not sure there must have been a lot of additional versions of Android rolled out. However I do remember that with version 7 Android I was still able to do a direct connection to LocoFi installed in the GP38. I don't know what has transpired since about a year or two ago. I do remember doing a lot of reverse engineering of the software, and had discussed at one time about getting the software into a "open source" configuration.
But that never happened. At this time you are pushing the "Little Grey Cells" to their limit to further discuss some of my previous efforts. Note: you might tell I am a POIROT fan.
If you would like I can discuss further with direct email. Let me know via this forum and I will give you my direct email. I am not sure this forum would allow that.
Regards,
Karin Anne Johnson P.E.
Palm Harbor, Florida
Have you been able to install an H-bridge in your GP38 and get it operational using a modified LocoFi system, with and without wifi network connection? Reason for asking is we have tried converting a 3 railer and a 2 railer using both the old and new modified Locofi systems, supplied by LocoFi, along with an H-bridge and can only get locomotives to operate when connected to a wifi network. When attempting to connect without wifi network being availabile we cannot get android cellphones or table to connect to locomotives. We have been communicating with LocoFi on the issue and seeking additional information as to why the communication link is failing. All indications point to the modification done to both model LocoFi systems and not to the phones or tablet. Your input appreciated.
Thank you Karin for sharing your detailed design. We hope that other G scalers looking to LocoFi™ their G scale locos for higher amps find it useful.
